Radio shuts off turns back on all the time??
Old 05-08-2012, 07:38 PM
Brewski4u1's Avatar
Question Radio shuts off turns back on all the time??
OK quick back round have a aftermarket radio, driving down the road it just shuts off, then turns back on and the windows stop working as well. So i started at the fuse box when its off and nothing, then i figured a loose ground well checked all under the hood (2 on the radiator cross member, and one on each fender well, block ground by the Alternator) i took all the off cleaned them with a wire wheel and sprayed w/ protector. i couldn't seem to find any grounds under the dash. if there is 1 or some and someone knows please let me know. well after all this still happens. switched back to OEM radio does the same thing.
i'm at a loss and wondering if this has happened to anyone else i feel it is a ground issue due to the fact a bump sets it off or hard acceleration or just the car running at a light. any help or ideas would be awsome.
if you have any other questions just ask.
thank you
Old 05-08-2012, 07:44 PM
SVTconfused's Avatar
sounds Body control module related...
or ignition switch/wiring
The following users liked this post:
Jordan Meyer (07-26-2020)
Old 05-08-2012, 07:48 PM
Brewski4u1's Avatar
mind you nothing else in the car is effected
Old 05-08-2012, 07:55 PM
mikey67's Avatar
Give this a read: https://ls1tech.com/forums/general-l...blems-fix.html
Old 05-08-2012, 07:57 PM
Brewski4u1's Avatar
ok thanks
on a side not i have also noticed that when taking the key out the radio and windows dont always stay working.... may be ignition problem?
Old 05-08-2012, 08:03 PM
Ellsworth's Avatar
its your BCM, pop that thing out are re-solder the 5 connections, it takes an hour tops and it works like a charm, happens to most of us
Old 05-09-2012, 01:58 PM
Brewski4u1's Avatar
^ thank you i was just gonna ask if anyone has a pic.!
Old 05-09-2012, 02:11 PM
Wile E's 98's Avatar
Awesome info. Mine does exactly what the op described. I thought bcm but wasn't sure because I have an after market stereo. Now I know.
Old 05-09-2012, 02:41 PM
I've already got it out and heading for the soldering iron.
Old 05-09-2012, 03:56 PM
Brewski4u1's Avatar
this will be my weekend project for sure unless i end up with a new gun after the gun show.
Old 01-26-2013, 05:00 PM
11_silverado_noob's Avatar
Thanks, I think u just solved my problem!
Old 01-29-2013, 07:51 AM
Justin_2000z28's Avatar
I had the same problem , it took me awhile to figure it out . I checked everything ground,replaced the head unit . Looked on here turns out it was the bcm causing it . It takes all of 30 mins to fix.
Old 02-09-2013, 07:08 AM
LightEmUpWS6's Avatar
Mine does the same thing but haven't fixed it yet. I found out to make it turn back on you need to HOLD the window button UP on and while u do that lock and unlock the doors like 2 times and itl turn back on, its weird but it works
Old 02-09-2013, 03:34 PM
BubaGumpShrimp's Avatar
yes all your problems are the bad solder joint in the bcm and not hard to fix at all, just a little pita to get the damn board out.
Old 02-09-2013, 05:12 PM
Ungrounded Moderator
WhiteBird00's Avatar
Yeah, I've always been amazed how doing that will fix broken solder joints. But only if you also curl the toes on your right foot and stick your tongue out the left side of your mouth.
Old 03-11-2013, 08:55 AM
FirehawkNS's Avatar
haha, I was doing that little trick for 3 years (car doesn't come out a whole lot, so it wasn't too big of a deal until I just couldn't take it anymore), but the last several times even that wouldn't bring it back
I took out the BCM last weekend and all my solder joints looked good except one, which was brown and cracked. Fixed that one and all is well. I found that I could make the radio cut off just by shaking the BCM before. Took me a while to commit to that fix as I have had two aftermarket Alarms with remote start installed and the wiring was a bit of a mess. Had to fix some shitty wiring practices the installer used first to insure that wasn't the issue.
Old 03-19-2013, 01:42 PM
Jadedbird's Avatar
my stereo shuts off and on as well too. but my windows work fine.
also my lights dim and get brighter and a quick pace. i was thinking alternators getting weak since it takes like 2 mins to kill my batter with the stereo on
my hvac lights also stay off until after the car heats up, then i can flick the hvac panel and it will shut the lights off and sometimes even kick them right back on...
Old 03-19-2013, 02:00 PM
Sickness7's Avatar
Thank you for giving me the solution to a problem that has been perplexing me all of last summer haha.
Old 03-19-2013, 02:52 PM
birner88's Avatar
Just did this a week ago. Pulled the bcm and found the bottom solder joint of the t shape was brown n cracked. Resoldered n have had zero problems since. My windows even roll up faster now. Thanks guys
Old 05-12-2016, 02:25 AM
tjlangel's Avatar
I was just able to fix a lot of issues in my car with this little bit of info I am still having a major problem though I can drive on the city streets all day long as soon as I hit the freeway though about 10 to 30 miles it will just shut off does anybody have any ideas please
Quick Reply: Radio shuts off turns back on all the time??
