TA radio/antenna question - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
Thread Tools Search this Thread
Old 05-25-2012, 01:26 PM   #1
JC70SS's Avatar
Default TA radio/antenna question
If I disconnect the power to the power antenna will I still be able to listen to CD's. I hate the look of the tall antenna and rarely listen to the radio. I wish somehow we could do a hidden antenna connected to the radio in the dash somewhere.
JC70SS is offline   Reply With Quote
Old 05-25-2012, 09:27 PM   #2
Yes you will be able to. I did this on my Trans Am because it got annoying listening to the antenna go up. I have a tape player and just plug in my Microsoft Zune and I can play raido through my Zune that hooks up to the tape player.
Beck2013 is offline   Reply With Quote
Old 05-25-2012, 09:42 PM   #3
Blu99T/A's Avatar
I took my antenna assembly completely out. I still pick up local stations pretty well, but mainly listen to cd's, etc
Blu99T/A is offline   Reply With Quote
Old 05-26-2012, 12:50 AM   #4
Decadence75's Avatar
There are also in-dash antennas that you can get. My power antenna didn't work when I got my car and I just never bothered to fix it since they no longer make them. I am able to get stations with a strong signal up to 40 or so miles from the origin city. Mostly I play CDs and play on a head unit with a USB drive soon. I also plan to delete the antenna completely when I get a paint job in the next couple years.
Decadence75 is offline   Reply With Quote
Old 05-26-2012, 02:28 PM   #5
JC70SS's Avatar
would you have any links to the in dash antennas?
Old 05-26-2012, 03:09 PM   #6
Here is a thread about installing a hidden antenna.
New hidden AM/FM antenna
Old 05-26-2012, 08:38 PM   #7
That's MISTER MODERATOR
Paul Bell's Avatar
Quote:
Originally Posted by Beck2013 View Post
...I can play radio through my Zune...
What's a Microsoft Zune??
Paul Bell is offline   Reply With Quote
Old 05-26-2012, 09:23 PM   #8
Quote:
http://www.zune.net/en-us/products/zunehd/default.htm
Or are you joking because hardly anyone has them.. I love mine. Haha
Last edited by WhiteBird00; 05-28-2012 at 01:55 PM. Reason: Merge consecutive posts
Old 05-26-2012, 09:32 PM   #9
Paul Bell's Avatar
Yeah, I couldn't help myself....
http://www.youtube.com/watch?v=16tWxbwAQ80
FWIW, I don't own a single Apple product.
Last edited by WhiteBird00; 05-28-2012 at 01:56 PM. Reason: Merge consecutive posts
Old 05-27-2012, 03:29 AM   #10
Apple sucks, Samsung Galaxy player 4.0 (with the Wolfson DAC) FTW (loud as **** and crystal clear), I bought my SGP 4.0 (8 GB model) a case, a 32 GB microsd and an extra battery and still came out 50 bucks cheaper then a 32GB ipod touch.
@ OP easiest to do is there is a plug in the wire about 3-6 inches from the base of the power antenna, just unplug that to disconnect the antenna. My antenna motor is stripped out (doesn't go up or down, but I can hear the gear spinning) so I'm gonna use those wires as a power source for my epicenter, thanks to a wiring diagram I got here.
Daniel Richards is offline   Reply With Quote
Old 05-27-2012, 07:11 AM   #11
Paul Bell's Avatar
I like the hidden antenna idea posted by decadence.
Old 05-27-2012, 06:37 PM   #12
1995blacktattop's Avatar
i just disconnected mine recently because the replacement antenna mast i put in started to show surface rust on it after only 6 months i can still hear stations if i want to, but i listen to my mp3 player 99% of the time (in dash unit with a usb stick attatched to the front of it)
and you're right, the antenna looks much better down, lol.
1995blacktattop is offline   Reply With Quote
Old 05-29-2012, 09:29 PM   #13
JC70SS's Avatar
how does one cut power to the antenna so it won't go up?
Old 05-29-2012, 09:35 PM   #14
Paul Bell's Avatar
Unplug it while it's down.
Old 05-29-2012, 10:13 PM   #15
Ungrounded Director
WhiteBird00's Avatar
Since nobody has mentioned the obvious answer...
Put a simple toggle switch in the antenna wire from the head unit. It's the pink wire in the OEM harness or blue in an aftermarket HU harness. When the switch is on, the antenna will go up and stay up. When the switch is off, the antenna will go down and stay down.
WhiteBird00 is offline   Reply With Quote
Old 05-29-2012, 10:48 PM   #16
JC70SS's Avatar
Where is the plug?
Old 05-29-2012, 11:08 PM   #17
Quote:
Originally Posted by JC70SS View Post
Where is the plug?
Behind the spare tire about 6" of wire length from the base of the antenna assembly.
Old 05-29-2012, 11:21 PM   #18
Paul Bell's Avatar
I thought " unplug it while it's down" was the most obvious answer......
Old 05-29-2012, 11:34 PM   #19
FWIW, I don't own a single Apple product.[/QUOTE]
I also hate apple products.
Old 05-30-2012, 07:43 AM   #20
Ungrounded Director
Sure, if you never want to listen to radio. But the OP also asked about a hidden antenna so he must at least occasionally listen to radio. A $2 switch gives him that option but allows him to keep the antenna retracted most of the time.
Related Topics
Thread Thread Starter Forum Replies Last Post
Power antenna questions redcamaro4140 Appearance & Detailing 8 01-26-2014 11:52 PM
Camaro power antenna? MTBSully Appearance & Detailing 8 12-09-2010 11:03 PM
Trans Am power antenna...Quick answer pls pitbull14218 Stereo & Electronics 6 04-04-2010 03:54 AM
Manually lowering power antenna? BlueBird346 Appearance & Detailing 4 10-29-2009 05:00 PM
heres an idea adm408 Appearance & Detailing 6 05-29-2002 01:25 AM
Tags
01, 99, antenna, electronics, fully, hate, mod, power, powered, question, radio, stereo, trans, vbulletin, wire, wont, ws6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
