12 Disc CD Changer Simple Question
Old 08-06-2012, 02:13 PM
wg871's Avatar
Default 12 Disc CD Changer Simple Question
I know this is a stupid question, and I read the FAQ and maybe I over looked it. I loaded up my factory 12 disc CD changer and I can not figure out how to play the CD's in the changer. I can play the CD in the head unit and if I eject it I cant figure out how to switch it to the CDs in the changer? Thanks
Old 08-06-2012, 02:25 PM
Moderator
jimmyblue's Avatar
"AUX" button, if it works. My trunk changer's been dead
for at least a year now, though, and it doesn't anymore.
Old 08-06-2012, 03:25 PM
wg871's Avatar
Sounds like that is my issue
Old 08-06-2012, 04:24 PM
Ungrounded Moderator
WhiteBird00's Avatar
Also, make sure you loaded the discs "upside down". The factory changer expects the discs to be label side down in the trays.
Old 08-06-2012, 10:45 PM
silverWS.6's Avatar
Pressing preset 4 would cycle the cd's in my cd changer unit
Old 08-06-2012, 10:57 PM
Conrad's Avatar
Not trying to hyjack. Does my car have the wiring there for the CD changer? What side would it be on in a convertible?
Old 08-07-2012, 06:55 AM
It would be helpful to know what kind of car and whether it has a Monsoon system.
All 98-02 Monsoon equipped f-bodies came with the wiring harness for the external changer pre-installed. You should find it in the left side of your trunk with the end wrapped in foam and taped to another wiring harness.
Old 06-17-2019, 01:15 PM
Richard Long's Avatar
I have 1998 Camaro Z28 convertible with trunk mounted CD disc player ... it does not work and shows a Err message on the radio screen...what does the Err mean?
Richard Long
richsboat@gmail.com
Old 06-17-2019, 01:20 PM
All of the error messages are numbered and listed in the Monsoon FAQ sticky at the top of the forum.
Old 06-17-2019, 03:31 PM
Where do I find the monsoon FAQ section ...I am very new to this site ..I am not sure my system is a monsoon as it was factory installed delco deltronics ..thank you for your patience and help
Old 06-17-2019, 03:47 PM
You are in the Stereo and Electronics section of the forums. When you exit your thread (this thread) you will be in that section listing all the threads that people are discussing. At the top of that list there are five threads above and separated from the rest - they are called sticky threads because they are permanently posted (stuck) at the top of the list. One of them is titled Monsoon FAQ. It has a wealth of information about the Monsoon premium audio system that was installed in 98-02 f-bodies (Firebirds and Camaros). I believe that all Z28 models (and Trans Ams) came with the Monsoon system as standard equipment but even if it didn't, most of the information applies to the base audio system as well - certainly the list of CD error codes does.
If you still have difficulty finding the sticky, here is the direct link to it: https://ls1tech.com/forums/stereo-el...nsoon-faq.html
Quick Reply: 12 Disc CD Changer Simple Question
