LED switchbacks.
Old Aug 6, 2012 | 02:52 PM
bene's Avatar
Trunion King
Default LED switchbacks.
I love the look of them but one of them is acting up. Driver's side is flickering like it's on fast strobe almost.
It's blinking fine, switches from amber to white when parking light is on and when just the DRL on, it switches off and on.
It only happens when it's on steady ie DRL.
Housing is tight and nothing is loose.
Any ideas?
I've looked into google and it seems normal but I didn't see/read any fix.
Old Aug 6, 2012 | 02:57 PM
216StealthSS's Avatar
do you have them front and back? either way LED's use way less voltage then a stock bulb so your car thinks its a "burnt out bulb" which in case causes a fast blink. you need load resistors in your turn signal harnesses. front and rear. that converts the regular car voltage into enough power to compensate for the LED's. correct me if i wrong people!
Old Aug 6, 2012 | 03:00 PM
bene's Avatar
Trunion King
It's just the front. It's not flashing fast at all, it's strobing or flickering when it's on steady like DRL. ( I have the electronic flashers.)
Old Aug 6, 2012 | 03:02 PM
ok... is that switchback made for the DRL lamps? bad connection in the socket?
Old Aug 6, 2012 | 03:09 PM
bene's Avatar
Trunion King
Yeah, it's a direct replacement. It can't be bad connection because it still functioning like it's supposed to be minus the flickering/strobing effect.
Old Aug 6, 2012 | 04:29 PM
WhiteBird00's Avatar
Ungrounded Moderator
216StealthSS has a very good question... are they made for DRL use? Just because they are a 3157 type replacement bulb doesn't mean they are compatible with DRL use. For example, v-leds.com specifically denies warranty for DRL use because their bulbs can't handle the heat of long term usage. I've had them start doing weird things after the heat damages the internal circuitry... such as flickering or randomly turning off one row or another of the LEDs.
Old Aug 6, 2012 | 09:53 PM
Danny2tek's Avatar
Yep, I did the DRL delete when I installed mine and they are still running strong.
Old Aug 7, 2012 | 07:18 AM
I can see that Whitebird does make sense.... i think the solution is what DANNY2TEK did.
Old Aug 7, 2012 | 01:21 PM
Danny2tek's Avatar
Old Aug 7, 2012 | 09:17 PM
junior98's Avatar
can you please post the link to where you got those 48 led switchbacks from?
Old Aug 8, 2012 | 07:16 AM
those are bad *** for sure danny2tek! now does the DRL have to be disabled with any aftermarket LED?
Old Aug 8, 2012 | 11:47 AM
Danny2tek's Avatar
Better safe then sorry the way I look at it. And I got mine "autolumination".
Old Aug 8, 2012 | 02:02 PM
Latch's Avatar
Why exactly do these bulbs not work as DRLs? Just because they're on for long periods of time? If that's the case then they shouldn't be used as brake lights either, because they stay on the whole time your headlights are on.
Old Aug 8, 2012 | 02:16 PM
Unless you drive around with your foot on the brake all the time, your brake lights are not on for extended periods.
The 3157 LED bulbs work like dual filament incandescent bulbs - they have a dim "filament" and a bright "filament". The tail lights are dim and only produce the equivalent of a 3 watt bulb so they don't generate much heat. On the other hand, the bright side (brake lights and DRLs) produces the equivalent of a 40 watt bulb which can generate more heat than the circuit board can handle.
The thing about LEDs is that they produce very little external heat (unlike a normal bulb) but they produce quite a bit of heat on the back side where they connect to the circuit board. So it's the circuitry that gets damaged rather than the LED itself. That's why you get weird symptoms like flickering.
Old Aug 8, 2012 | 02:26 PM
Latch's Avatar
Ah, damn, I was thinking the DRLs ran in "dim" mode like parking lights do. Thanks for clearing it up for me.
Old Aug 8, 2012 | 02:37 PM
bene's Avatar
Trunion King
You guys might be on to something. If these LED switchbacks aren't made for DRLs wouldn't both of my LEDs flicker?
Only one side of mine does the flickering, the driver side. With both getting equal wattage, both should get the flickering effect.
Old Aug 8, 2012 | 03:41 PM
Not necessarily... at least not yet. The effect of heat can be quite different on individual bulbs so you may not see the other side flicker for a while (or possibly ever).
The easy way to confirm is to swap the bulbs side to side and see if the problem switches sides.
Old Aug 8, 2012 | 03:46 PM
bene's Avatar
Trunion King
I'm going to try that this coming weekend.
Old Aug 25, 2012 | 04:24 AM
bene's Avatar
Trunion King
Originally Posted by Latch
Why exactly do these bulbs not work as DRLs? Just because they're on for long periods of time? .
Just for an update. It's not DRLs causing the LEDs to flicker at least not on mine. Upon further observation, my DRL housing socket for the LED has given up the ghost. I have to buy a new one from Autozone to replace it as it doesn't firmly hold the LED 3157 light in it to get good contact on power.
FWIW, the LEDs were cool to touch even when it was on for minutes to an hour.
Old Aug 30, 2012 | 01:59 PM
NitoV's Avatar
How exactly did you do your delete?
