Why does my amber light work only when signaling?
I have a 98 T/A that has developed a new lighting issue.
My drivers side amber light only works when I signal left. Other wise it stays off.
The passenger side light is functioning normally, blinking when I use the remote to lock and unlock the car, staying on while the car is running and signaling, and both of the amber side marker lights are functioning....
What could be causing this?
the front facing amber bulbs are DUAL filament bulbs, one is for turn signals and the other is for the DRL, odds are one of the filaments is burned out, pull the bulb out and check/replace it. if that doesn't fix it then you might have the issue my passenger side does when ever the humidity gets to high, my passenger side will just randomly not work then be working the next day.
Ungrounded Moderator
But you're correct about the symptoms... if the turn signals and DRLs work but the bulb doesn't flash when locking/unlocking and doesn't go on with the headlights then the dim filament is probably burned out. (It could be a wiring or socket problem but it's much more likely to be just the bulb.)
