plug to delete antenna?
Is there a plug available to delete the power antenna on a Trans am? I would like to relocate my antenna inside the panel in front of the spare tire. I may lose a little reception in the process, but I'm not worried about it. I just want to plug the hole with a flush(ish) plug.
The following users liked this post:
jclimon (07-01-2019)
Save the manuals!
You'll probably get no reception at all by putting an antenna inside a metal rear fender. You can hide it, but it needs to go in a place where radio waves can get through.
Here are some solutions:
https://ls1tech.com/forums/stereo-el...m-antenna.html
This is how you get it to look "good": https://ls1tech.com/forums/general-m...haved-you.html
The paint and body on the car is perfect so I don't want to weld it up. I didn't know if someone found a plug that would fill the hole semi flush. I did something similar to my 300ZX and put a Silverado antenna in the rear hatch area by the latch. It worked pretty good.
Save the manuals!
