Stealth Box Fitment
Stealth Box Fitment
Just installed my sub & stealthbox here recently. While I am very pleased with the sound, I thought the fitment would look just a bit better. Here it is as it sits now:
It seems like it should go deeper in the cubby hole but just won't fit. I read that some people cut out the carpet before installing their stealthbox? Will that work?
looks like it's not seated back all the way, have you tried simply removing that section of carpet that the box covers (that cubby hole is separate from the rest of the rear carpet, FYI)
Update: I removed the carpet but still no dice. I filed down some of the corners of the box, fitment was still better but no good enough. Pulled the carpet back more and found out that the some guy at the factory put way too much seam sealer or whatever it's called in the trunk area. It was over an inch high in some spots. Got a razor and shaved it off where the sub was going. Put everything back and it's nearly perfect.
