Window switich Help Firebird, Stock control panels aftermarket windows
Hello, I am needing a little help I installed aftermarket power windows in a firebird and I would like to use the firebird control panel for each side instead of the ugly aftermarket one. Does anyone know the wiring diagram for switch prongs which ones which?
Ungrounded Moderator
Left side switch
A - ground
B - to pin B on right side switch
C - to pin E on right side switch
D - to left motor down
E - to left motor up (factory connection actually goes to express down module)
F - 12V power
Right side switch
A - 12V power
B - from pin B on left side switch
C - to right motor up
D - to right motor down
E - from pin C on left side switch
A - ground
F - 12V power
Right side switch
A - 12V power
