can i pull the abs & airbag bulb from cluster
Old 12-29-2013, 06:22 PM
zaaronz's Avatar
Default can i pull the abs & airbag bulb from cluster
Im not sure what section to post this-- but
I have the airbag and abs inop light on my gauge cluster- I know why there are on but my question is--- Can i pull the bulb from those lights so they arent on all the time? I thought i read somewhere that it messes something up but im not sure- Has anyone ever done this?
Old 12-29-2013, 06:42 PM
sick_tight's Avatar
someone was saying they were LEDs and youd have to desolder them and if you take them out the open circuit causes issues. but i could be wrong. i guess you could paint the inside of the display (on the backside).
Old 12-29-2013, 06:45 PM
(SS)'s Avatar
You pull the bulb with no issues.Used car lots do it all the time to hide things.
Old 12-29-2013, 07:08 PM
zaaronz's Avatar
Yea i sure dont want to make a bigger problem by pulling them. I also read somewhere that thet were soldered in on a circuit board- Which is why i was wondering if you could pull them. I'll probably just leave em alone lol
Old 12-29-2013, 07:12 PM
JC316's Avatar
Don't know about GM's, but Ford's will chime their heads off at you if you pull the airbag light. Activates the door chime every few seconds until you change the bulb.
Old 12-29-2013, 07:15 PM
sick_tight's Avatar
i would think it would be easiest to plasti dip the backside of the light so the light doesnt shine through and if you need to take it off you just peel it off.
Old 12-29-2013, 07:24 PM
JOHNNY59's Avatar
they're a LED and solder to the circuit board. easiest way is to cover up the LED.
Old 12-30-2013, 05:21 AM
Save the manuals!
wssix99's Avatar
I fixed this for my skip shift light. You can lift up the overlay, cover the LED with a small piece of electrical tape, and then replace the overlay. Just make sure to follow the proper proceedure to make sure your gauge needles go back in the right place.
Old 12-30-2013, 07:33 AM
My6speedZ's Avatar
x2, simple and effective. I did this for the ABS, airbag, and traction control.
Old 12-30-2013, 10:26 PM
zaaronz's Avatar
Yea i got it figured out now- looks like just blocking the led is the best and easiest way- thanks guys!
Quick Reply: can i pull the abs & airbag bulb from cluster
