moonsoon noob
Yes, they *can* be made to work but are not what I would consider an optimal replacement. You need to be asking about the differences between a conventional two way speaker and a convertible component set.
https://ls1tech.com/forums/stereo-el...selection.html
https://ls1tech.com/forums/stereo-el...placement.html
https://ls1tech.com/forums/stereo-el...nsoon-amp.html
https://ls1tech.com/forums/stereo-el...-speakers.html
If you want a simple recommendation on what to do:
1) buy some speakers: http://www.keeaudio.com/id47.html
2) take the doors apart: http://www.firebirdnation.com/pdf/doorpanel.pdf
3) do not use the included external crosssover modules. Attach the appropriate wires, and install the speakers into the plastic cradle bracket.
4) Re-assemble
5) Enjoy.
...not so daunting, is it?
Its really not that hard. Just make sure you have the appropriate speakers in-hand before you go to the trouble of taking the doors apart. You may also want to read up on the use of external crossovers. Just do your reading first, buy the appropriate parts, and go forth... its not as big of a deal as you are making it out to be. While you have to doors apart, consider adding a few sheets of dynamat or raamat or something like that.
4) Re-assemble
5) Enjoy.
4) Re-assemble
5) Enjoy.
Ungrounded Moderator
You might want to consider the suggested replacement speakers depending on how much it would cost you to get factory replacements. I've seen some people selling individual Camaro Monsoon door speakers for as much as $160 each on eBay. That would make the CDT speakers from Kee Audio a bargain at $150 per pair. Plus you get much better sound quality and speakers that will last much longer.
