Relocating Stereo Deck
well you're just flat out NOT gonna find a store that sells a "mount" for a CUSTOM application like that, aftermarket mounts are only for adapting the STOCK location to use a single din radio.
This will have to be a custom fabricated piece, depending on the tools you have access to, you could go to a local hardware store and find a piece of metal that you can cut and bend to the shape needed then drill holes to mount to the screw points holding the HVAC panel and holes to attach to the sides of the new headunit where the new headunit has spaces for screws.
