Big 3 Wire Lengths?
Big 3 Wire Lengths?
Looking to do the big 3 upgrade soon, checked the thread in the sticky but the images were all gone and couldn't find lengths.
Does anyone have the lengths for the 3 wires, and are there any other write-ups?
I will be using 0AWG OFC welding wire.
Reason for doing the upgrade is because I will be running a PPI P900.4 (4x 225WRMS @ 2ohm) and a PPI P1000.1 (1000WRMS @ 1ohm). I will be keeping the stock alt for now, unless I have problems.
Thanks for any help.
I would plan for about 10-12 feet total, and you'll want another 20 feet for your amp power line and a couple more for your ground wire from your distribution block so call it 40 feet and that should have you covered, better to buy 2 or 3 extra feet then to come up 6 inches short.
Here's a thread I started awhile back when I still had my Camaro- https://ls1tech.com/forums/stereo-el...3-upgrade.html
Lots of good info from the links within that thread.
