Whats the proper way to wire through firewall?
Old 04-18-2014, 12:06 AM
David_viny's Avatar
Default Whats the proper way to wire through firewall?
Old 04-18-2014, 12:53 AM
Daniel Richards's Avatar
amp power wire?
generally everyone goes through the grommet behind the PCM and run the power cable down the passenger side of the car.
Old 04-18-2014, 06:09 AM
DamonZ28's Avatar
And removing the PCM makes it a lot easier too. You don't have to unplug it, just move it out of the way.
Old 04-18-2014, 10:58 AM
David_viny's Avatar
I'm just wondering in general. Like right now I need to wire a few gauges to the engine. Oil pressure, temperature, water temp, etc. So just thin wires. Also eventually would like to relocate battery to the back so I guess I could use the pcm grommet.
Old 04-18-2014, 07:07 PM
xenergyx's Avatar
there should be another one on the driverside same spot too
Old 04-19-2014, 07:12 AM
Ungrounded Moderator
WhiteBird00's Avatar
There should be but there isn't.
Quick Reply: Whats the proper way to wire through firewall?
