Center Console Wiring Help
Old 07-15-2014, 07:53 PM
Mr Pancake1225's Avatar
Exclamation
Howdy. I own a 1997 Trans Am. I noticed the lighter by the shifter was pushed into the console so today I decided to remove the console to fix it and noticed a loose set of wires. Can anyone help and tell me where these go if anywhere at all. Its an automatic if that can narrow it down at all.
Also, the second outlet doesnt work.
Last edited by WhiteBird00; 07-16-2014 at 07:03 AM. Reason: Merge consecutive posts
Old 07-15-2014, 09:53 PM
M4N14C's Avatar
Looks like the plug for one of the cigarette lighters or the TCS switch if you have one.
Old 07-15-2014, 09:55 PM
I have no TCS switch.
Old 07-15-2014, 09:59 PM
M4N14C's Avatar
Is it connected?
Old 07-15-2014, 11:19 PM
Is it connected?
As far as I can tell.
Old 07-16-2014, 07:21 AM
Ungrounded Moderator
WhiteBird00's Avatar
That is the connector for the traction control switch. The five wires that would be used by the switch are brown, grey, brown/white, black/white and purple/white. The harness is there even if you don't have traction control.
As for the outlet, check fuse #11 CIG/ACCY.
Old 07-16-2014, 12:52 PM
Thanks for the info. Will check the fuses.
Quick Reply: Center Console Wiring Help
