Power Wire for Amp.
Power Wire for Amp.
What is the best route for the power wire from the battery to the rear of the car? I figured I would ask here before I tore into the car trying to find the best path. I am installing a #4, and it is a little stiff but still flexible.
One thing I don't like, is there is no room behind the trim piece along the door. You can't really tell unless you really look, but still don't like the way there is no room for the cable.
Trust me when I say it was easier the second time. The first time I tried I spent awhile trying to get the PCM back in because the TCS kept falling back down in the way. I tried to tie it up out of the way with zero luck. So it is just sitting there behind the PCM not tied to anything.
Don't think my amp wire goes behind the trim piece but under the carpet along the door then through the sails to the hatch.
