Amp is installed.
So no more spare tire? The only problem I could forsee is the amp overheating on a hot day when you are really jamming out with the music pumping. There wont be any air circulation in that location. I do like the idea of it being hidden and stealth though. I made up an amp rack 10+ years ago, then mounted it on the opposite side of the taillight location. That way I can still drop in my t-tops when im topless and the amps have plenty of fresh air to stay cool.
I don't drive the car to much. But I did think about the cooling issue. I thought about cutting some vent holes in the panel down at the bottom so it can't be seen that well. Make them look like a grill, about 6" to 9" long and probably a 1/8" big. Just something to let a little bit of air escape.
can't help but notice the you used some cheap audio/video rca's (I see the yellow one hanging there), I would suggest getting better RCA's that are shielded and meant for use in car audio.
just a question, are your RCA's and power ran on the same side of the car? if so reroute the RCA's, as a general rule RCA's and power lines should be kept as far away from each other as practical and if they have to cross need to do so at as close to a 90 degree angle as possible to reduce interference in the system.
I thought about a fan to. I'll wait and see how warm the amp gets. The RCA plug goes behind the amp to a RCA adapter. I will change to a higher grade later, I just wanted to make sure everything worked. The only wires going to the front of the car are the power wire to the battery and the wire going to the fuse block for power.
