window problem after autotrix type fix
Old 09-02-2014, 07:14 PM
White6SpdZ28's Avatar
Default window problem after autotrix type fix
So I did my own autotrix fix with the passenger window. Tapped in under the kick panel for wiring. Window works great however will only work off the passenger side switch. Not the drivers. Worked perfectly fine before. Could I have possibly spliced into the wrong wires. I believe it was light blue and brown if I remember correctly off the top of my head
Old 09-03-2014, 07:38 AM
Ungrounded Moderator
WhiteBird00's Avatar
The connections must be made inside the door otherwise you are modifying the control wires rather than the motor wires.
Old 09-03-2014, 08:22 AM
Alright. Guess I'll do that.
Quick Reply: window problem after autotrix type fix
