Cleaning up my wiring harness and need help.
Old 02-05-2015, 07:39 PM
1320Chicken's Avatar
Default Cleaning up my wiring harness and need help.
I've started removing wires and plugs in my harness that I'll no longer need. So far I've repinned the O2 sensors and removed the other two that I won't be using. Some of this stuff has been unplugged for so long I have no idea what theses plugs are. I'm unpinning the wires and removing them completely.
Here's what I need to remove
All AIR wiring
All A/C wiring
Does anyone have pictures of the plugs so I am 100% sure I'm removing the right wires? All I'm going off of right now is a pinout diagram. It's a 99 trans am. Thanks
Old 02-05-2015, 08:02 PM
99Z28camaro's Avatar
Subscribed..
Old 02-07-2015, 12:02 PM
LetsRide's Avatar
In for the pics and answers. I too need to do this.
Old 02-07-2015, 06:34 PM
Here's some links I've come across so far that have been helpful. Really all I've been able to remove are the egr and a couple of the a/c plugs. I repinned the o2s and got rid of the 2 plus I won't use. It appears that the bulk of the a/c and air wiring are in the front body/headlight harness. I'll get the engine harness bundled up and move on to that taking pics as I go.
http://www.ls1fc.com/pdfs/LS1HarnessID.pdf
http://www.ls2.com/boggs/torques/99pinpcm.htm
http://lt1swap.com/2001_PCM_CONN_PINOUT.htm
http://www.thirdgen.org/forums/ltx-l...rt-finish.html
This last link would be gray for anyone wanting to strip down to nothing and start from scratch. If you guys have questions I'll do my best to answer them as I go. I'm pretty much learning as I go on this.
Quick Reply: Cleaning up my wiring harness and need help.
