Does anyone sell the PIE GM9-AUX anymore?
Old 02-19-2015, 10:45 AM
CaptainCrunch42's Avatar
Default Does anyone sell the PIE GM9-AUX anymore?
Greetings,
I am trying to install an aux input to my 2002 SS as painlessly as possible. I mistakenly picked up the PAC AAI-GM9 kit on eBay and installed it to no avail, since apparently it requires the CD changer to work (which I don't have). Does anyone know where I can find the PIE standalone product? I tried the usual Amazon/eBay with no luck.
Tommy
Old 02-19-2015, 04:40 PM
Ungrounded Moderator
WhiteBird00's Avatar
Another option is the USA-SPEC PA11-GM45, especially if you're an Apple fan (iPod, iPhone). It is designed primarily as an iPod integrator for the factory head unit but also provides left and right RCA jacks for auxiliary input. It is about $25 more expensive than the GM9-AUX was ($106 on Amazon) but it is still readily available.
Old 02-19-2015, 09:08 PM
Thanks for the heads up, got a good deal on that unit from the auction site!
Old 03-18-2015, 08:12 PM
Blownbayou's Avatar
would have traded mine (non changer) for yours.... dammit. Would love to have an aux and not lose my changer
Old 04-09-2015, 10:56 AM
FormulaZR's Avatar
Do you know is USA-SPEC makes an adapter (that will work without a CD changer installed) that is not designed around the iPod? I realize the PIE is gone...and since I have no CD changer I can't use the PAC - but I will also not be using an iPod.
Old 04-09-2015, 11:11 AM
As mentioned, the USA SPEC device is designed with special IOS features but also has ordinary RCA jacks for connecting any non-Apple device.
Old 04-09-2015, 12:36 PM
FormulaZR's Avatar
Gotcha, thanks.
Didn't know if there was another USA SPEC unit that did the same thing, but without iPod specific functionality (for maybe slightly less money).
Old 04-09-2015, 10:07 PM
Yep, that's how I'm using mine (with an aux input) and it works great
Old 04-11-2015, 12:03 PM
Tally TransAm's Avatar
i just stumbled across this thread. do you need a head unit that supports a changer to use the PA11-GM45 interface? I do not believe my 99 head unit supports a changer
Old 04-11-2015, 09:42 PM
Yes, the USA-Spec and all similar adapters require that the head unit support an external CD changer. The PAC model is the only one that actually requires a changer be present... the others only require HU compatibility.
Old 10-09-2015, 05:59 PM
Larmec's Avatar
I've got an Aai-gm9 that I mistakenly got for my HU that does not have an external slave unit and does not work without one. I'd be interested in trading you if you're still up for it?
Old 12-24-2015, 01:40 PM
FormulaZR's Avatar
Anyone know if this one works? http://www.oemautosound.com/p-536-au...t-pontiac.aspx
Old 01-19-2016, 06:01 PM
SuperSport346's Avatar
I just wanted to thank WhiteBird00 for the suggestion on the USA-SPEC. I have a PIE GM9-AUX installed in my Camaro, and wanted to install one in my 2001 Silverado. Since I couldn't find any, I looked on Ebay for the USA-SPEC and got a brand new one for $45. Installed it tonight, and it works perfect. I had to flip one of the DIP switches to use the RCA inputs, but otherwise it works just like the old PIE unit.
Old 03-02-2016, 10:29 PM
Reaper_SS's Avatar
Sorry to dig up an old thread. But I have a 02 monsoon without the cd changer. This looks like it should work but I just want to make sure
http://www.autotoys.com/x/product.ph...ctid=4296#tabs
I just bought a AAI-GM9 like a dummie so I want to be sure before I waste anymore money on this. I wish I didn't have the button on the steering wheel or id just get an aftermarket. Hate the thought of buttons that don't work.
Old 03-03-2016, 07:06 AM
Yes, that adapter should work according to the description but the line on the summary page that says "PAC version will ship" concerns me. You might want to post your question on their page.
You don't have to give up steering wheel controls when installing an aftermarket head unit. Almost all head units over the last several years have a steering wheel control port for connecting an adapter so that your buttons will work. And there are universal adapters for those few head units that don't have the wired connection but do have an infrared remote.
Old 03-03-2016, 09:17 AM
Reaper_SS's Avatar
Well that changes things. Any idea what that option on the aftermarket HU might be called that allows aftermarket HU to accept the steering wheel controls? I'd rather do that. Thanks for that info
Old 03-03-2016, 09:31 AM
Various manufacturers and suppliers use different terminology but they are fairly consistent. Kenwood calls it "OEM Remote Interface", Pioneer calls it "wired remote", Crutchfield has a line item in the option details list called "Steering Wheel Control Compatible".
Stick to the major brands (Pioneer, Kenwood, Sony, JVC, Alpine, etc.) and you shouldn't have any problem. Avoid the cheap stuff like Boss, Dual, Pyle, and the no-name Chinese brands.
Quick Reply: Does anyone sell the PIE GM9-AUX anymore?
