Backseat delete speaker box
Not like your design, but YES it has been done, BY ME for one and atleast one other car I have had the chance to sit in.
FYI, you DON'T want 6x9's behind you, especially that close to your head it will pull the soundstage to far back.
I started by building a frame from a single 2x4 (the first pic) which later got revised to be just the front section, then I designed the box with forward facing ports, then after a while I redesigned it, removed the existing ports and created a new port firing backward.
Where would you put 6.75" components in the back? Just leave the in the sails? I like to feel like the sound is all around me, I'm not into the front staging setups.
no pics but I do have this video
this is as far as I got with it, I've since yanked it out to put the car back to stock interior so I could sell the car, the ultimate plan was to blend it into the sail panels so it looked like it was meant to be there.
also here are some others, the last one is the one I've sat in, but he had more money in his subs then I had in my entire system at the time.
https://ls1tech.com/forums/stereo-el...eats-subs.html
https://ls1tech.com/forums/stereo-el...ld-camaro.html
I wouldn't put COMPONENTS in the back AT ALL, trust me ANYTHING that does highs AT ALL will just make it sound like everything is coming from the speaker in the sail panel just behind your head and make it next to impossible to balance out, just do the 6.5 midrange or if you have the monsoon amp still in play a set of the Bazooka subs from KeeAudio.com in the sails.
Firebird rear seat sub box update 6-8-13 - YouTube
