any decent options for door speakers besides cdt??? camaro with monsoon
I bought the whole kee audio basic speaker upgrade close to a year and a half ago for my car. I am pleased with the subs but one of my hatch speakers and one of my door speakers are blown. I really don't care much about the hatch speakers however i would like to get a new set of front speakers especially since imo they weren't quite as loud as i wanted them to be. I know kee audio sells an upgraded model of door speaker but was wondering if there are any other decent ones out there
You guys do realize the monsoon speakers are a 6.5" inch speaker with a tweeter they aren't regular coax speakers right? That's why im asking this question can't just buy regular coax speakers unless i wanna lose the tweeter plus the factory amp won't work well with just any speaker
Well just look for component speakers that can be coaxially mounted, I know there are several brands out there capable of that, alternatively you could mount the tweeter higher in one these http://6litereaterdesigns.com/store/...roducts_id=260 or by locating a good spot and drilling a hole in the door panel to locate the tweeter higher at which point ANY component becomes an option.
I guess i need to be more specific, i already know regular coax speakers will work i also know i could run a tweeter seperately. Basically i want something like i already have with the cdt's which have the tweeter mounted on the speaker i just want them to be louder. I know kee audio sells another model of cdt speaker which is better but just trying to see if there is something similar out there.
a few examples of these are:
Kicker 41KSS654
Kicker 41KSS674
there are more you just have to go looking for which models have that capacity, this is what the CDT speakers do, which is why they are marketed to you camaro guys, I was just giving you options that opened you up to a MUCH MUCH wider selection of components, because I would NEVER suggest anyone hook up a normal coaxial speaker in place of a component setup like these other guys did.
Ungrounded Moderator
The suggestion of Image Dynamics by fspeedster also fits the coaxially mounted component set requirement but they are quite expensive (starting at $200 and going way up from there) and you would have to check the clearance because they mount the tweeter so that it sticks out in front of the woofer basket.
Memphis also makes what they call "synchronous" components which are the same thing - tweeter mounts in the center - and in similar price ranges.
Perhaps my last post was not clear, JUST A FIND A SET OF COMPONETS THAT LIST THEM AS BEING ABLE TO BE COAXIALLY MOUNTED TWEETERS.
Kicker 41KSS654
Kicker 41KSS674
Kicker 41KSS654
Kicker 41KSS674
