Sealed Beam Question
Hey guys, I'm looking to put HIDs on my car, I've done it before on my other trans ams, and I'm wondering what sealed beam conversions you guys use now, couple of years ago I used Eurolamps, but I've seen some people talking about Hella, and LMC. Just wondering which I should go with. thanks fellas!
LMC is the straight up swap for a part that is a direct drop in, the Hella is a Projector (technically a halogen projector) and requires an adapter plate (which you can either attempt to build or purchase at a additional cost), but it gives you a proper cutoff that prevents you from BLINDING oncoming traffic, the LMC's are cheaper, but the Hella 60mm projectors are BETTER, but at about twice the cost all in over the LMC's also just an FYI the Hella projectors use a 9005 bulb and the LMC's use a 9006 bulb.
Save the manuals!
I have the LMC's and they are 3x better than stock. (In terms of the distance I perceive that I can see.)
The more money you spend, the greater you will think they are - that's human nature. I don't recall seeing any real data on any one of the options to tell if they are "worth it."
I do feel a hell of a lot safer with the LMC's and can see much farther with them.
also I've run the LMC in both halogen and HID configurations, even the halogen is an improvement over the stock lights, but is NOTHING next to the HID.
Copy & Paste Moderator
I'd recommend sticking with Halogen bulbs if you get the LMC housings.
Also you can upgrade to HIR Halogen bulbs instead of Standard Halogen and get a lot more light without ruining the beam pattern.
9011 replaces 9005
9012 replaces 9006
You can find them on Amazon. Philips and Wagner are the two most common brands currently selling them (GE and Toshiba made earlier generation of them). Avoid fakes (if it has a blue coating, it is fake).
9011 replaces 9005
9012 replaces 9006
9011 replaces 9005
9012 replaces 9006
9011 replaces 9005
9012 replaces 9006
