Where To Wire My Radar Detector
Im sick of the wire hanging down to the cig lighter(detector above the rearview)..I ran the wire up threw the headliner..and i figured id wire it right into the fuse panel. Well i cut the wire for the detector and it ended up being to smaller wires inside..Red/White...Where can i wire this in at? I dont want it on all the time..im gonna want it to turn off after the cars off etc..thanks for any help.
Ungrounded Moderator
Tap into the empty connector on the fuse panel labelled IGN with the red wire. Run the other wire to a good ground such as one of the bolts under the dash. Double check with a test light or multimeter that the inside of the connector that plugs into the detector has power and the outside has ground (to avoid reverse polarity).
Now your radar detector will go on and off with the ignition switch.
