Anyone use Harrison Labs FMODS in line crossovers?
If these are for your subs or mids that have an amp don't waste your money. Amps have that kind of range filter already built in for you. Also most head units have high and low pass filters built in for this too.
I am thinking <150Hz for subs (2 stealth boxes), 150-500Hz for mid bass (sails), 500-3k for mids (doors and hatch), and >3k for tweets (doors and hatch). Using 3 amps. My head unit crossover ends at 250Hz, and I don't see any amps that crossover abode 500Hz.... so... I am looking for firsthand experience with these FMODS in line xovers.
Most aftermarket highs and mids come with cross overs to use.
Also after market head unit should filter for the rca's from the get go to limit frequency. Sub cut of at 300hz, mids 100hz-1k? And highs should start like 200hz and up. Well how they use to be.
Why the stock radios had the eq on them type setup.
Sorry if this doesn't help but you should never need those.
Also, I could have totally separate tweeters and midrange with these.
Originally Posted by FCar2000TA
The amps that I want, and my headunit only crossover up to 250Hz, so I'd need to have the headunit HighPass set to 100Hz, and then use one of these 500Hz filters to get the desired mid-bass bandpass range.
