Question bout a head unit in 03 truck
Old 06-24-2004, 12:01 AM
Baltimore Whore
Mangled03gmc's Avatar
Question Question bout a head unit in 03 truck
I HAVE BEEN DEBATING PUTTING A NEW HEAD UNIT IN MY 03 GMC TRUCK.FROM WHAT I HEARD IS THAT THE ONLY WAY I CAN DO THIS IT TO RELOCATE MY OLD HEAD UNIT SOME WHERE ELESE IN THE TRUCK.MY BUDDY JUST HAD ONE PUT IN ON HIS NEW TAHOE AND THAT IS WHAT THEY DID.WHATS THE DEAL.THANKS
Old 06-28-2004, 02:26 AM
VinMan2's Avatar
Do you have factory bose and onstar?
Old 06-28-2004, 12:27 PM
Deranged Rat Fink
badjuju342's Avatar
most new GMs have a data serial wire that is in the head unit , it has different functions including driving some of the warning lights , (example: you have use the head unit to turn off the" change oil light" in new Impalas) . Metra now makes an adapter that allows you get rid of the stock head unit. before (especially if the radio said RDS) you had to relocate the old stock unit to retain those functions. the adapter is not cheap but neither was the relocation harness. you can check it out at www.metraonline.
Old 06-28-2004, 09:55 PM
VinMan2's Avatar
Metra's harness is nice but if you speak to one of their techs they will tell you it is better to keep the factory radio somewhere in the car because certain people have found out that the car will not comunicate right with the diagnostics machine if the car has to go back to the dealership.
Old 06-30-2004, 01:35 PM
Baltimore Whore
Yeah The Truck Has That Rds **** In It But As Long As I Can Take The Old Unit Out That Is Fine.it Shouldnt Make The Truck Run Shity Or Any Thing Like That If The Stocker Is Replaced Should It. No I Don't have the bose,onstar.Thanks for the 411.
Old 07-20-2004, 11:55 PM
396 Camaro SS's Avatar
If you don't have OnStar or Bose, you can get a Peripheral GMCO adapter and everything will work perfectly.
Old 07-21-2004, 01:26 AM
blk03's Avatar
what if you have Bose?
Old 07-21-2004, 08:44 PM
Not a problem..........just requires a different adapter. The Peripheral part number if you have Bose is GMAH24B.
Old 07-22-2004, 11:40 AM
Baltimore Whore
SO THEN WITH THAT OODAPTER I CAN REMOVE THE FACTORY UNIT ALL TOGATHER
Old 07-22-2004, 11:02 PM
That is correct!!
Old 07-23-2004, 10:00 AM
Baltimore Whore
Thanks For The 411 I Will Have To Check In To That Harness. DO YOU HAVE THE PN FOR THE HARNESS FOR NON ONSTAR/BOSE
