Alarm Issue after heavy Rain
Since the heavy rain yesterday, my car will not stop honking after I use the remote to lock the doors. It will honk twice at the initial locking, then honk twice about every 4 seconds after that. I am assuming water has entered the alarm brain? Anyone had this problem?
Blake
Blake
Blake
Blake
this also means reprogramming your key FOBs....
Had this problem with mine to it will quit once it drys out. To fix this take the spare tire cover off on the passenger side in the hatch. There will be a black box mounted to the wheel well "this is your shock sensor" just unplug the harness that connects to the box. All this does is disable your alarm and your keyless entry and everything will still work. Give it about a day or two so it will dry out. Then plug it back up and see if it still honks at you. Also cleaning your inner fenders will cause this to.
