Dim Headlights Help needed ASAP!
Old 08-16-2004, 10:01 AM
Brandon_TA's Avatar
Unhappy Dim Headlights Help needed ASAP!
hey guys/gals.....
I cant figure it out... my driver side headlights have been very very dim here lately.
This is what happens... I turn them on and the high & low are dim on driver side. on the pass. side the low works fine,but the bright is dim. (this is when i have the low beams turned on). when i turn on the high beams just the passenger side works.... I am thinking i have a bad ground, or some sort of relay is corroded.... Has anyone ever had this happen before? Is there anything i could do to try and fix this problem.. I don't have warranty anymore so that option is gone.
thanks, any help is appreciated.
Old 08-16-2004, 03:14 PM
Brandon_TA's Avatar
anyone??? please!
Old 08-16-2004, 11:33 PM
Hayze's Avatar
Sorry, wish i could help but I no nothing about it. Did you try searching? Just a thought...
Old 08-17-2004, 07:15 AM
Brandon_TA's Avatar
yes, i tried searching and found nothing... I had my passenger side low beam burn out so i went ahead and replaced it last night, and now they work fine. Hopefully the old bulb was just drawing alot of current or something.... Hopefully i fixed it.
