Gutted Dash: Neither Windows work!! Need Help!!!?????
Old 08-28-2004, 11:52 PM
Jucin's Avatar
Default Gutted Dash: Neither Windows work!! Need Help!!!?????
We removed the Hvac and Heat/AC reassembled everything and we went to roll the windows up and neither of them have power. When the key is foward and you hit the window up button the Seatbelt light blinks and the door alarm beeps very fast. What did we miss some relay, everything was plugged in that is getting used besides airbag module, heat ac controls. Any help.?????
Old 08-28-2004, 11:56 PM
I can shift faster than you.
Jason99T/A's Avatar
The power window ground is located on the passenger side of the car with a 15mm bolt that attaches it to a stud that is part of the chassis. It is very easy to see once you remove the kick panel on that side. This is something to look into.
Old 08-29-2004, 12:08 AM
Haytoes's Avatar
are all the power and grounds attached to the BCM? I belive that controlls the windows and other misc. functions inside the car.
Thought you retired!
Old 08-29-2004, 12:44 AM
Jucin's Avatar
BCM?
Its a 99 Camaro helping a friend. Those grounds are attached that was my first thought.
Old 08-29-2004, 09:49 AM
Jucin's Avatar
anyone?
Old 08-29-2004, 11:08 AM
Haytoes's Avatar
body controll module, it controlls a ton of interior functions. If you can wait till tomorrow I can get you a wiring diagram off Alldata and fax it to ya. Two way me if you want that stuff.
Old 08-29-2004, 11:25 AM
Jucin's Avatar
Body control module is hooked up. Let me know on that diagram.
