12 Disc
12 Disc
I recently purchased a 99Z with NO options whatsoever, but I still love it. I was thinking about installing the 12 disc changer (since mine doesn't even have cd). Is the wiring harness already in the car? Will it just plug right in or am I looking at major problems?
Ungrounded Moderator
Yes, the harness should be already installed. You will find it taped to the speaker harness under the left rear (hatch area) speaker. The CD changer will just plug right in. You will need to do some work to mount the changer since the factory welded-on bracket won't be there. The easiest way is to put a piece of wood under the carpet and screw the changer brackets into it.
if you want i can sell you my monsoon stereo and cd player, it is out of my 02 trans am and has the in dash cd player as well as the 12 disc changer, let me know if you are interested.
