Fuse connection question
My car threw some codes that I determined were due to a fuse blowing. When I opened up the fuse box to see if this was the case, I found the fuse was missing entirely. I also found a little hook tool in the engine compartment. Apparently the last place I took it to took out the fuse and dropped it, tried to fish it out, then got sidetracked and forgot about it.
So, no biggie, I went and bought a new fuse. I went to put it in, and found that one of the terminals is missing as well. Well, that makes it a bit more complicated. What does it take to replace one of those? Can you just buy the little metal piece and slide it in, or is it more complicated than that?
This was a little red 15 amp fuse, btw.
