wiring question
Old 10-21-2004, 12:51 PM
scifone's Avatar
Default wiring question
where do you guys run your power wires? is there already somewhere in the firewall to run it through or are you guys drilling a hole? i will be using 4 gauge. also i have a 6 point cage in my car so that kinda complicates things. it is a 98 z28. thanks in advance for the replies.
robby
Old 10-21-2004, 01:05 PM
2FAST4U's Avatar
Pass. side under the PCM. remove the 2 bolts holding the pcm swing the pcm out of the way and there is a 2" black gromet down there. I have seen 0/1ga in there
Old 10-21-2004, 01:06 PM
scifone's Avatar
awesome... thanks a bunch. gonna tackle that on sunday.
Old 10-21-2004, 01:11 PM
iamsickofitall's Avatar
you can get a power connection in the fuse panel inside the car too...just need a .10 cent connector...can plug into either a constant power connection or one that is powered when the key is in the on position in the ignition
Old 10-21-2004, 02:19 PM
2FAST4U's Avatar
You don't want 4ga taped into the fuse box!
Is this for audio or did you move your battery to the back?
I have my batt. in the trunk and taylor 2ga running on the pass. side bettween my cage bars and the out side of the car. everything fit fine. But I also rewired the whole car,so there are no other wires on the pass. side!
Old 10-21-2004, 02:44 PM
scifone's Avatar
yea its for a stereo and the battery is still up front... how hard was relocating it?
Old 10-21-2004, 03:23 PM
2FAST4U's Avatar
Realy easy BMR has a relocate kit realy nice mountes in the passenger rear! If you are thinking about it do it now and save money and time!
http://www.bmrfabrication.com/misc.HTM
Old 10-21-2004, 03:41 PM
scifone's Avatar
did it come with the wires to run to the back for the starter and stuff?
Old 10-24-2004, 09:10 AM
2MuchRiceMakesMeSick's Avatar
Why dont you just run that 4 guage up to the battery post like everyone else in the world. Relocating your battery is doing nothing contributing to making your voltage drop.
Old 10-24-2004, 09:19 AM
SilverWS6_2002's Avatar
Just leave the battery up front. I have 1/0 guage running through that passenger side grommet without a problem. Works out great.
Old 10-24-2004, 12:59 PM
2FAST4U's Avatar
But for racing weight in the rear pass side is a very good thing! And it realy cleans up the engine bay!
2muchricemakesmesick... there wouldn't be any voltage drop for the audio system as I would think the amps would be closer to the battery(trunk area) the only time the taylor battery wire kit would evern see a voltage isue is under starting! But I had no problem with that with crapy 4ga audio wire and the taylor is the same as welders wire!
Old 10-25-2004, 02:03 PM
scifone's Avatar
running it through that grommet behind the pcm was a piece of cake. the pcm was a biotch to get back in though... until i realized that i should remove the clips on the wiper cowl and then it just fell into place...
Old 10-26-2004, 08:23 PM
The source of the charge is the alternator. When volt loss was an issue I ran a battery up front and a 'few' batterys in the back with a battery isolator when I was competing in iascca db drag racing.
