XM Tuner, Pioneer or Terk?
I just purchased a Pioneer deh-p7800mp stereo headunit and wish to get XM radio hooked up to it.
I was in circuit city and found a 2 piece Terk system (one is the tuner/antenna, and the other is the adapter to adapt it to my pioneer). I think the pro's of this system are that it is a total of $100, it has a relatively small antenna, and if I have any problems with the unit I can just bring it back to Circuit City (1/2 mile from my house) and get it taken care of.
My other option, is going with the pioneer brand GEX-P910XM tuner and AN91XM antenna. Pro seems to be that it is all pioneer, which may offer some better sound quality or more options then the terk.
Basically I just want to know what you guys think the better option would be given your own experiences/opinions. Would the Terk limit my sound quality/display readouts in any way? I lean towards staying all pioneer, but it is almost double the price and if they are very similar I would rather spend that money on something else.
Thanks
Thanks
Copy & Paste Moderator
The Pioneer one was available at BestBuy and CircuitCity.
EDIT:
I just did some searching and can't find it on either of their sites. I have a 903 (earlier model I think) in my car right now. I bought it over a year ago (almost 2). You dont have to get that antenna specifically either. Any two lead XM antenna will work.
EDIT:
Here is a site that I have bought stuff from before:
www.myradiostore.com
Here is a link to the Pioneer unit:
http://www.myradiostore.us/xm-radio-...ex-p910xm.html
They are located in New York too, so It'll get to you quick.
You can use any two wire antenna.
The antenna connections are green and yellow.
Check out this pic for an idea (connections to the right):
http://store1.yimg.com/I/yhst-546081...81_1819_457581
www.myradiostore.com also sells antennas/adapters/etc
They also sell the the Terk unit and its a adapters, but its only 2 or 3 dollars cheaper.
I dont know about the difference in sound quality or operation but the Pioneer unit with antenna costs $75 more than the Terk Unit and adapter. I'd rather stick with all the same brand, but that isn't a small difference. All I can say is that since you can get (and subsequently return) the Terk unit easily, give it a try. If it doesn't work/sound well, return it and order the Pioneer unit (and antenna). Just talk to XM about swapping from one radio to other before you do it. You need to register the radio's ID with them for it to work completely (there may be some fee/difficulty involved in swapping the radio ID attached to the account -- I dont know). Although you can get Channel 1 (demo channel) without activation. I guess you can hook it up and test it with Channel 1 and decide before activation.
