bypassing monsoon amp?
I am installing a new head unit and speakers and i pulled out all of the monsoon stuff. I want to use the factory wires. my question is do i just connect the speaker inputs to the outputs from the monsoon amp acording to this chart...
http://www.houston-f-body.org/tech/m.../AmpCamaro.htm
Should I ignore the subwoofer wires??
Thanks, Justin
Thanks, Justin
Thanks, Justin
Thanks, Justin
if you are adding in your own subs and amp later, than I wouldn't wire them up.
