Installed Autometer shift light, Having problems - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
Thread Tools Search this Thread
Old 05-01-2005, 11:34 PM   #1
matt94z's Avatar
Default Installed Autometer shift light Having problems>>
The shift light will flash when you turn the key on, so I know it should work. The problem is that no matter which rpm pill I put in it, the light will not flash. I was told to tap into the whit wire on the black pcm plug. Is this right? What else can I try??? Help.
matt94z is offline   Reply With Quote
Old 05-02-2005, 04:03 AM   #2
regorih383's Avatar
Wish i could help but, for what i remember its not the white wier
regorih383 is offline   Reply With Quote
Old 05-02-2005, 12:29 PM   #3
Chuckels's Avatar
unbolt the PCM and look for white wire #13 on the RED connector
Chuckels is offline   Reply With Quote
Old 05-02-2005, 06:28 PM   #4
matt94z's Avatar
Thanks man, I'll give try that tonight.
Old 05-02-2005, 11:00 PM   #5
dhdenney's Avatar
I do not have an Autometer light but rather an MSD so I realize different companies are gonna have different schematics for their products. But for comparison: my light's RPM input wire goes to the coil's negative terminal for signal. If you have an MSD ignition, it will have a tach output connector on it.
dhdenney is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
