Need help with wiring
Old 09-01-2005, 05:27 PM
1sicLS1's Avatar
Default Need help with wiring
K 1st off Im new to this board so be easy on me
I have searched for this type of question and really didnt get what I was looking for. Alrighty here is my situation---(my main goal is to not have to run new wires for my speakers) My head unit is aftermarket(kenwood kdc-x879) I am changing my door speakers and rear sail panel speakers with JL audio xr series) Now i Know if I use the stock amp it will go into a 2 ohm load. Now if I completely bypass the monsoon amp will I need a metra 70-2001 32 pin harness? Now do I connect my speaker wires from my amp (jl audio 300/4) to the metra harness? Also if I connect the stock wires to the speakers will it be in a 4 ohm load ? Or do I need to run all new wires? Sorry if these are dumb questions, But you gotta learn somehow Thanks in advance
Old 09-01-2005, 05:41 PM
1sicLS1's Avatar
Oh by the way I have a 99 Z28
methane's Avatar
unplug the harness from the amp and tap all your speaker wires in there, thats how i installed my 4 channel amp. heres a link that will tell you what color the speaker wires are.
http://www.houston-f-body.org/tech/monsoon/index.htm
Old 09-02-2005, 03:21 PM
1sicLS1's Avatar
ok...but do I still need to buy the metra harness or just cut the plug and match up
Old 09-05-2005, 12:34 AM
1sicLS1's Avatar
anyone????????
