Where To Tap For Ign.switch Power
Here's the deal, I need to wire up my alky controller, a/f ratio wideband and my boost controller with ing.switch power. The alky controller has a 10 amp fuse, the wideband a 3 amp fuse, and the Blitz SBC I-DII boost controller(?amps). What's the best way and where do I get the ign. switch power from. My truck is a 1998 ext.cab GMC Sonoma-4.3 auto. Thanks for any help. PEACE>Tony
You should have an ignition controlled power wire going to the rear of the radio. Not sure if it would cause any problems if you tapped it though. Wish I could help more. Good luck.
