ABS inop TCS off light and I didnt' touch the brakes!
I was wiring up a harness to the front of the car and got its power for it from the Fuse box. I have since rewired it to be from the battery after it caused all sorts of headlight/signal/horn/light motor problems. Though the TCS off and the ABS inop light are still on? I checked the fuses, they are both good underneath the hood.
Any Ideas?
Any Ideas?
I would start by disconnecting whatever you added by pulling the fuse.
Then I would reset the computer by disconnecting the battery and letting it set for 30 minutes or so.
While your waiting replace the fuses because sometimes they can look good but they are actually bad.
