Trip odometer resets when cold! Help! - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
Thread Tools Search this Thread
Old 10-18-2002, 08:09 AM   #1
Chop-Foo Director
PendragonZ's Avatar
Default Trip odometer resets when cold! Help!
Hey guys, I've noticed something very odd here.
When the temperature drops to about 32 or below,
my trip odometer decides to reset itself to 0.0.
What's going on here? Anything I can do to fix
this?
-brian
PendragonZ is offline   Reply With Quote
Old 10-18-2002, 12:54 PM   #2
Default Re: Trip odometer resets when cold! Help!
There is a TSB on this issue back for the '99 models. I think the TSB # is 99-08-49-009. Take it to the dealer and it should be covered.
Batmobile/SS is offline   Reply With Quote
Old 10-22-2002, 12:43 PM   #3
Chop-Foo Director
PendragonZ's Avatar
Looks like it! I'll have to take it in and
get it fixed.
Thanks much!
-brian
Old 10-23-2002, 01:04 AM   #4
Yep the same thing happened to my 99. The ODO would reset and all the gauges peg out at the other position. Exp...the speedo would go to 155 and the TAC would go to 7,000. It is the Gauge cluster going bad.It will start doing it all the time not just when its cold. The dealership will fix it.
PewterZ is offline   Reply With Quote
Old 10-26-2002, 07:24 PM   #5
Will they take care of it even if it's not under warranty, since there is a TSB?
O2BQIK is offline   Reply With Quote
Old 10-27-2002, 01:21 AM   #6
Quote:
Same question, also where can we get a copy of the TSB??
Speedfreaks101 is offline   Reply With Quote
Old 10-28-2002, 08:31 PM   #7
Quote:
Oh damm....Im not real sure....You can give it a shot...
Old 11-02-2002, 10:51 AM   #8
Not likely. The only time that you have repairs done out of warranty at the Dealers expense is under a safety recall. Other than that, your SOL Dude.
A TSB is information that is made available to the Technicians by the Manufacturer. TSB info is not intended for our eyes. Just because GM is aware of a problem and puts it on the TSB list, doesn't mean that it will get repaired at GM's expense outside of your original warranty period.
DROPTAWP is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
