JL Audio W3, and Fosgate amp... stock deck and door speakers??
Old 11-28-2002, 08:16 PM
mike#9's Avatar
Default JL Audio W3, and Fosgate amp... stock deck and door speakers??
I have the JL W3 that is custom fitted to the trunk where the CD changer is, and I have a Fosgate amp. My question is, can I hook all this up without changing the deck and door speakers? I know that it is a different OHM load but is it still possible?
01' SS
Old 12-01-2002, 07:40 PM
mike#9's Avatar
Default Re: JL Audio W3, and Fosgate amp... stock deck and door speakers??
Anybody???
Old 12-01-2002, 09:24 PM
slow's Avatar
yes you can, you need a Line Output converter for the signal, and you just add this with the rest of the system <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Where did you get the box made?
Ryan.
Old 12-02-2002, 09:08 PM
Snootch's Avatar
You might be able to get away without the line out converter. Depending on the age/model of amp you have, The amp might have speaker-level inputs built into the amp. Just tap + and - off both the rear speakers, and connect to the Hi level inputs. If your amp dosent, then you will have to use a RCA to Speaker wire adapter, otherwise known as a Line Output Converter available at your local stereo shop.
Old 12-02-2002, 10:11 PM
mike#9's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by slow:
<strong>yes you can, you need a Line Output converter for the signal, and you just add this with the rest of the system <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ryan.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It is the box that JL Audio makes to fit the compartment where the CD changer is. I just bought the amp... maybe 4 months ago.
