relocated battery, where should i connect the line from trunk to?
i ran the line from the trunk to the engine compartment but the place where the stock battery connection is is now where my turbo is, can i connect the positive to the other side of the engine bay where the red plastic piece conencts to the fuse box? so its away from heat? also if i do this can i just leave the postitive conection ont he side alone or does it have to be connect to a positive power source?
Draw
This is how you need to reconnect all wires.
Sure you can relocate your wires to drivers side, but you NEED to follow the drawing. You cannot connect BATT direct onto the red plastic piece connected to the fuse box. You have to reroute the wires.
