Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Stereo & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 05-26-2007, 03:54 PM   #1
funkymonkeys409's Avatar
Trader Rating: 4
Send a message via AIM to funkymonkeys409
Default write up: hi and low beams on same time
well i fugured it out and thouhgt id make a write up on how to do it.
before:
after:
well first off you need to unscrew and pull down the bottom covers under the steering wheel.. look down the steering wheel column. on the left side of it about 1/2 way up from the firewall theres gona be a high/low headlight dimmer switch connection. these wires are what go up to the switch itself up at the top of the column.
its a little tricky to get this out because theres not a whole lot of room for your hand to fit up there. once you do get it out, you'll have to splice into the TAN and YELLOW wire with a short piece of wire. make sure its a heavy guage wire to handle the current running through it. i used 14 guage.
make sure to clean it up so that you get a good connection
then you can solder the wires together or not, your choice. make sure to wrap it up with some electrical tape or shrink wrap it.
once you have that done, just plug the connector back together. and put everything back together. now with this done you will be able to have just your low beams on and when you switch the high beams on the lows wont go off. if you drive with your fog lights on they will still go off when the highs are swithed on
__________________
1998 camaro Z28...gets me around
funkymonkeys409 is offline   Reply With Quote
Old 05-27-2007, 11:34 AM   #2
CULATR's Avatar
Trader Rating: 79
not to question your work or piss you off or nothing but was thinking about how to do this to my camaro and was wondering is it safe to do that ???
__________________
Wooderson (dazed and confused) "Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some fkin' muscle."
CULATR is offline   Reply With Quote
Old 05-27-2007, 12:02 PM   #3
mycamaroSS's Avatar
Trader Rating: 3
nice write up..im gonna do this today
__________________
2001 Camaro SS #1752: ???rwhp ???tq- LS6 Intake l LS6 Heads l ORY l JetHot Sterling Coated Pacesetter LT Headers l Cut-Out l SLP Lid l Brembo Rotors
mycamaroSS is offline   Reply With Quote
Old 05-27-2007, 01:23 PM   #4
Trader Rating: 4
Quote:
safe for you personally or for your car? i searched for a write up like this but there wasnt any and so i just gathered all the info i neened. this is what made me know it was safe for my car
Quote:
Originally Posted by Kage
...do you need a relay or a fuse for this mod or not?
Don't want to burn my shit up ya know.
Quote:
Originally Posted by WhiteBird00
No relay is necessary. This mod just makes the Camaro wiring configuration the same as on Firebirds which already leave the low beams on with the high beams. The Firebird wiring has the low beam power bypass the dimmer switch to ensure they remain on, so this mod just adds the same bypass to the low beam side of the Camaro dimmer switch. Of course, make sure you use a big enough gauge of wire for the bypass.
__________________
Old 08-12-2007, 08:58 PM   #5
bww3588's Avatar
Trader Rating: 38
Send a message via ICQ to bww3588 Send a message via Yahoo to bww3588
would it be safe to use 18 gauge wire on this?
__________________
1998 Z28 under construction
bww3588 is offline   Reply With Quote
Old 08-14-2007, 11:32 PM   #6
Trader Rating: 1
18 ga is definitely too small.
__________________
'00 Pewter Camaro SS Convertible A4
http://www.fquick.com/RoadHazard/
RoadHazard is offline   Reply With Quote
Old 08-16-2007, 03:23 PM   #7
Super Speed's Avatar
Trader Rating: 8
Can't forget that its illegal in most states
__________________
Mods - Lid, Smooth Bellow, SS Headers, ORYP, Borla, MSD 8.5 MM wires, LS7 Clutch, NGK Tr6's, spray and a 233/239 on a 112 LSA...
Super Speed is offline   Reply With Quote
Old 08-16-2007, 06:04 PM   #8
OMGWTFBODY's Avatar
Trader Rating: 5
Send a message via AIM to OMGWTFBODY
Mine does that from the factory.
__________________
http://www.ls1tech.com/forums/image.php?type=sigpic&userid=86670&dateline=123222  2196
OMGWTFBODY is offline   Reply With Quote
Old 08-17-2007, 10:37 AM   #9
Ungrounded Director
WhiteBird00's Avatar
Trader Rating: 4
Quote:
No it's not - otherwise every Firebird would be illegally equipped since they have lowbeams on with highbeams. States generally limit the number of forward facing white lights to four. That's why the fog lights go off when you use the highbeams.
__________________
White 2000 Trans Am
usual bolt-ons and some appearance/convenience mods
WhiteBird00 is offline   Reply With Quote
Old 08-19-2007, 05:56 AM   #10
flippincamaro's Avatar
Trader Rating: 21
If you got Hids in both high and low beams, Will this put to much strain on the wiring harness for the lights?
__________________
02 Z28 convertible A4 2tone Black/Blue,Custom built rearmount turbo setup, Kenny Stock! 93 Chevy indy 500 pace truck LSX turbo, four link setup for drag. 93 Z28 project car, 2000 Chevy Tahoe two tone pewter on dark graphite grey on black 22"s wifes ride.
(I like people who BUY a 10 sec car and then brag about it. Thats like hiring someone to bang your wife and then bragging about the kid)
flippincamaro is offline   Reply With Quote
Old 08-19-2007, 02:58 PM   #11
2009 Pontiac G8
Trader Rating: 0
HIDs draw less power than halogens
__________________
2009 Pontiac G8 GT
Need a subwoofer for your sail panels? Forget that and see this:
Need a subwoofer for your stealth box? See this. | Sound Deadner Info
dragonrage is offline   Reply With Quote
Old 08-19-2007, 04:26 PM   #12
Trader Rating: 21
Awesome then i will be doing this, Thanks for the writeup
__________________
Old 08-20-2007, 06:17 PM   #13
Trader Rating: 1
nicee.. now it will be nice a "how to polish the headlights" thread
cxpcman is offline   Reply With Quote
Old 08-21-2007, 08:22 AM   #14
Ungrounded Director
Trader Rating: 4
Quote:
Well, since that isn't an electrical problem, I found this thread in the Appearance & Detailing section: Fixed my yellow/cracked headlight today (pics)
__________________
White 2000 Trans Am
Old 01-05-2008, 07:00 PM   #15
RedLS's Avatar
Trader Rating: 4
I just did this to my head lights and it came out GREAT! Now all i have to do is get all the hids. LOL Ill post up some pics tomorrow.
__________________
http://i275.photobucket.com/albums/j...27_YZKEC-L.jpg
1999 Camaro Z28 M6
Fidanza Aluminum Flywheel, Spec +2, Adjustable Master, TSP Carbon Lid, Nitto 555R 315's on 17" ZR1's, Berger w/ Mirror inserts, SS Hood, SS Spoiler, K&N, Open Headers, !AIR, !EGR, !DRL
RedLS is offline   Reply With Quote
Old 01-06-2008, 04:36 AM   #16
Kage's Avatar
Trader Rating: 11
Cool
Quote:
LOL.
They also sell a wiring kit w/relay for this type of mod for like $20.00, it's nothing new.
I just though i'd put my .2c in.
Good job never-the-less.
__________________
...Shitz-n-Getz 99SS...
I'm like a sore cawk....
I Can't BE BEAT!!!!
Kage is offline   Reply With Quote
Old 01-06-2008, 06:20 PM   #17
RedLS's Avatar
Trader Rating: 4
I would rather spend .25 cents and do it this way took me like an hour to do.
__________________
1999 Camaro Z28 M6
Old 01-06-2008, 08:17 PM   #18
wssix99's Avatar
Trader Rating: 1
Normally, I would shy away from jumping wires like this because it will cause double the current to flow through some of the wires when both sets of lights are on. (This could lead to blown fuses.)
I checked the Factory Service Manual and this seems A-OK. Interestingly, Firebirds will do this from the factory, but only the Camaros switch between the two sets of lights. Upstream of the headlights, the Firebird and Camaro consistently share the same wiring gauges, so the Camaro wires should also be good for the current. (This mod effectively mimics the Firebird's wiring.)
One point - the tan and yellow wires are 12 ga., so I would suggest also using a 12 ga. jumper. If you want to avoid soldering, you can also use 12 ga. splice clips available at Radio Shack. (12 ga. clips are usually tan in color - be sure not to use red or blue ones.) (Splice clips are also very easy to work with in tight spaces.)
There are also other wires that you can jump to get the same effect; however this example (tan and yellow) is the best way to go as it won't increase the current going through the high beam switch.
wssix99 is offline   Reply With Quote
Old 01-17-2008, 02:00 AM   #19
SIC LSX's Avatar
Trader Rating: 8
Send a message via AIM to SIC LSX
kinda ghetto way to do it you can get some connectors to make it a little more cleaner
__________________
99 m6 Z28
11 sec club & cam only
Tuned in SD by Brian shell. LS7 clutch, Tsp 231/237 cam 112LSA,Full boltons, UMI lca's, relocation brackets, Qa1's up front and DMS out back.
Also kown as DansRedZ28
SIC LSX is offline   Reply With Quote
Old 01-20-2008, 01:39 AM   #20
Trader Rating: 0
My low beams on:
Low beams on and fog lights i installed on
My high beams on:
High and low beams on
My lows are always on in my 95 camaro, whats so special about this???
__________________
87 351w coupe
90GT converted LX stock 5.0 AOD
Chattanooga is offline   Reply With Quote
Tags
1998, 96, beam, beams, camaro, dimmer, high, highlow, jumper, low, lowhi, mod, switch, tahoe, wire, work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
