rockford 501s amp, 500x1@4ohms bridged, what kinda sub?
Old 06-10-2007, 01:47 PM
2klude's Avatar
Default rockford 501s amp, 500x1@4ohms bridged, what kinda sub?
My friend gave me a rockford 501s amp. The specs are...
125 watts RMS x 2 at 4 ohms
250 watts RMS x 2 at 2 ohms
500 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
4-ohm stable in bridged mode
I want to go with a single sub setup. I am looking for a balance between SQ and SPL. what sub would you recommend me looking into?
I assume I am looking for a single sub which is 4ohm so i can draw 500watts from the amp in bridge mode?
thanks guys.
Old 06-10-2007, 02:20 PM
fredmr39's Avatar
yea you'll want a sub that is SVC 4-hom, or DVC 2-ohm
what are the specs on the box it will go in? do you want a 10" or 12"? what kind of music do you listen to? what is your budget?
Old 06-10-2007, 02:39 PM
2klude's Avatar
I am not sure if i want a 12" or 10" does it make a big difference... I listen to a lot of rap and r&b music. I would say my budget for the sub is around 200ish. Keep in mind i will probably search for a used sub on ebay so 2-300 is my budget new.
Old 06-10-2007, 05:30 PM
KEE AUDIO's Avatar
These are the ones I went with:
http://cgi.ebay.com/ebaymotors/BRAND...spagenameZWD1V
I still have my JL W3's up for grabs cheap as well.
Quick Reply: rockford 501s amp, 500x1@4ohms bridged, what kinda sub?
