How much can the stock charging system handle?
Old 06-19-2007, 09:48 AM
Starion's Avatar
Default How much can the stock charging system handle?
My car is wired for a 10" stealth sub + an amp. When shopping for a sub and amp do I need to restrict my purchase so that the stock charging system won't be affected? I'd like to put an amp and a sub in, but not if I have to go monkeying with the charging system to handle it. Is there a baseline for the tipping point of the stock system?
The amp will be only for driving the sub, nothing else.
Old 06-19-2007, 10:08 AM
95bat's Avatar
I'd say up to 1000 watts and you should be fine.
fredmr39's Avatar
agreed - 1000 is a good, safe cutoff
Old 06-19-2007, 10:24 AM
rotwiler's Avatar
I have 2 10's and running a 500 watt rms old school mtx amp. I could go a little bigger, but I don't like the surging etc and seems to be a perfect cutoff point for me.
Old 06-19-2007, 10:25 AM
fredmr39's Avatar
yea also depends a lot on how efficient your equipment is
Old 06-19-2007, 11:21 AM
Starion's Avatar
Thanks for the responses.
I was looking into a 250w amp to drive the sub. Looks like that shouldn't be a problem at all.
Old 06-19-2007, 12:05 PM
Gordon0652's Avatar
I'm running 1500 watt alpine amp w/ stock battery and alt w/o a cap, and it works awesome!!! But 1000 watts sounds more reasonable...
Old 06-19-2007, 12:13 PM
wickedwarlock's Avatar
I'd say 500 watts tops and even that's cutting it close. Take into account night driving with a/c on.
Old 06-19-2007, 04:30 PM
95bat's Avatar
500 watts is only about 35-40 amps of current... our cars have a 120 amp stock don't they? Mine did, at least.
Old 06-20-2007, 06:52 AM
some due, some have 102amps too.
take in mind, that's at 4-5k rpms too. idle is about 20amps.
Old 06-20-2007, 06:59 AM
not all of them. Some have the 102 amps. If I'm not mistaken, most of them are the 102 amps.
take in mind, that's at 4-5k rpms too. idle is about 18 amps.
Old 06-20-2007, 08:53 AM
oh yeah, big time db problem this morning.
