is a 200 amp alternator overkill??
Old 06-24-2007, 11:13 PM
SS101's Avatar
Question is a 200 amp alternator overkill??
i plan on running lots of electrical assecories (about 10 nexus gauges, 200 watt sub (yeah i know it's small), electronically controlled air suspension, nitrous and boost controllers, two external cooling systems (one for the trans and one for the diff - each has a 12v pump and heat exchanger w/ fan) cut outs, and a bunch of other little goodies)...whatdo you think?
Old 06-24-2007, 11:56 PM
transam5.7lt1's Avatar
200 amps are great! But I hear they work like stock at idle, its until you get the rpms a little over 1200 when they work.
Old 06-25-2007, 12:45 AM
ultraz's Avatar
i say its overkill. You should be fine in the 160-180amp range. Add up the amperage from all the extra accessories and find one suitable for your needs.
Old 06-25-2007, 12:55 AM
SpaZMaN's Avatar
from what i've gathered from your post, you mean to have an airbag system, nitrous, turbo, and some other goodies? holy **** batman.
Old 06-25-2007, 10:11 AM
95bat's Avatar
It definately won't hurt to have one
Maybe on a cheap, POS alternator. Mine puts out over 100 amps at idle.
Old 06-25-2007, 11:57 AM
SS101's Avatar
thanx for the info guys...i'm a wiz with engines but a totaly idiot with electronics
Old 06-25-2007, 01:15 PM
White_LightningZ's Avatar
I always wondered if it didn't take more power to turn a bigger amp alternator? Would you gain or lose power depending on increasing or decreasing from 160 to a 200 amp alt?
Old 06-25-2007, 03:06 PM
95bat's Avatar
It all depends on the pulley. Mine is a direct replacement... didn't gain or lose any engine power, just gained electrical power
Old 06-26-2007, 08:01 AM
So basically get the biggest amp alternator with a stock pulley size and you'll lose nothing? Seems win win to me.
Old 06-26-2007, 09:48 AM
95bat's Avatar
Honestly, even if the pulley were smaller I don't think it sucks up that much power. I think the crank pulley is the one that matters most.
