New Head Unit for '02 Z06; how to keep 8" woofers?
Hey guys,
I just purchased an Alpine IDA-X001 from Crutchfield for my '02 Z06. The head unit comes with all the necessary stuff, wiring harness, mounting plate, etc.
However, the wiring harness that crutchfield supplies does not have provisions for the 8" woofer in the door. With their wiring harness, you lose those speakers. Losing them is not an option for me, as I'm trying to improve my stereo, not diminish it.
Does anyone know of a wiring harness that I can purchase that will allow me to keep the subs in the door?
Or, will I be forced to try to splice and wire them myself?
Any help is much appreciated!
Thanks,
Ralph
Thanks,
Ralph
I Would Go Check At Best Buy Or Circuit City They Should Have One Because My Camaro Has A Six Speaker Sytem Factory With 8' Subs And I Got My Harness From Circuit City And All My Speakers Work Just Fine.....
Ungrounded Moderator
Originally Posted by JustinID
Corvette, not Camaro.
...Best Buy Or Circuit City...Should Have One Because My Camaro Has A Six Speaker Sytem Factory With 8' Subs
Originally Posted by pentavolvo
pac adapter is the way to go
Thanks!
You didn't mention you had a Bose system. If that's the case then it's no wonder the aftermarket head unit didn't work properly. The new style Bose systems send audio signal to the amp at a constant volume and the serial data line sends volume control information separately.
If you have a Bose system you must use a Bose adapter to install an aftermarket HU. On the other hand, if you don't have a Bose system then a Bose adapter won't work.
