How do i wire center speakers to work
i have a after market head unit.i installed everything properly however the two speakers in the walls by my head do not work is there a trick to wiring these speakers ? do i have to splice the wires and connect them to the two rear hatch speakers?
Originally Posted by 95bat
The ones in the walls by your head? Where exactly?
you have 2 in the door too in the middle and two in the hatch area
I think he's refering to the sail panel speakers...which only produce bass frequencies and no midrange or highs. This is probably why you aren't hearing anything. If you require full range sound from the sails you can to wire to the hatch speakers..or since you have an aftermarket HU you can wire directly to it and bypass the Monsoon factory amp altogether.
