Any Formula owners replace DRL/turnsignals yet?
Both of mine are cracked and in pieces and I cant seem to find any suitable replacements. Anyone else have to replace theirs? I just finished installing my Blazertech Cyberwhites for the foglights and that came out great, now I just need the drl/turn signals.
Copy & Paste Moderator
I was thinking about getting another set of aftermarket fog light housings to put there and modify them to use the 3157 bulbs and sockets. So basically fog light housings converted into turn signal housings.
I was referring to aftermarket fog light housings.
(I fixed my post above.)
No they can't be used "as is" for turn signal use, but maybe they can be modified. Its an idea I had, but I haven't tried it yet.
I had no idea just how worn they'd become... I was very surprised at the difference in the overall look with the GM replacements.
I have some photos showing what it looks like behind there. The passenger's side is pretty easy to do, but the driver's side is a bit tight. I can't remember if I removed the passenger's side headlight bezel, but for sure the driver's side required coming in from underneath. Two screws to remove if I recall.
Passenger's side:
Driver's side, showing unit removed (and giving a sense of the poor amount of room to work behind this one):
