Window switch wiring
So I have an electric cutout and I want to wire up an extra window switch that I have for it. Its proving to be a pain because I cant figure out what prongs of the 5 that are on the back to put power or grounds to. So can anybody shed some light on this matter.
I am doing a window switch so I can put it up where the ASR and fog light switch is. Also because its a rocking switch.
Ungrounded Moderator
If you're using a driver's side window switch, connect your power supply to pin F. Then you will have output on both pins B and D when the switch is pressed up and output on pins C and E when the switch is pressed down.
If you're using a passenger's side window switch, connect your power supply to pin A. Then you'll have output on pin C when pressed down and pin D when pressed up.
