headunit and windows cut out intermittantly...??
ok like the title says... intermittantly my headunit and windows stop working together at the same time.... it can go weeks without it happening or it can happen 5 days in a row.... theres no pattern to it.... now the head unit and windows circuit share the same ground and i check the ground and it was ok... but i didnt chase it through the harness at all... i just wanted to know if anyone else has had this problem and what the problem was... cas is a 1997 lt1 firebird formula m6.... any help would be appreciated...
I had something simlar the other day for the first time. I came out to the car after work and it had rained. Well I got in the car and everything started fine and I go to put the windows down and no go. Then i try to turn the radio on, no go. Then I see that the clock is dark and no lights on the radio...then turning out of the parking lot a minute later, everything turned on and has been fine. Sound similar to what you had happen?
(I dont know the cause just wanted to join and see if you hear anything relating to that)
