Hifonics Brutus BXI-606 or Cadence TXA-750D
Ugh.... I don't know much about this stuff. I think these two 600 watt amps are similar priced and powered. I don't really know specs though. The amp will be powering an Alpine Type R dual 2 ohm voice coil. Anyone enlighten me?
http://www.cadencestore.com/ProductC...&idproduct=386
http://www.maxxsonics.com/hifonics/amps_brutus.html
How much is your budget?
I have the Rockford Fosgate Punch P4002 for $165.00 shipped. NIB!!!!
RMS power:
100watts x 2 @ 4ohms
200watts x 2 @ 2ohms
400watts x 1 @ 4ohms bridged mono
compared to the Cadence Power ratings:
SKU: TXA-750D
1 x 275 Watts @ 4 Ohm
1 x 375 Watts @ 2 Ohm
1 x 600 Watts @ 1 Ohm
Plus Rockford Fosgate has always underated there amps.
If you need more power than that I have this:
MA Audio M1900XE 1000watt monoblock amp for $155.00 shipped.
Mono Block High Performance Amplifier
Subsonic filter: 20-50Hz
1 x 500W RMS @ 4-Ohm Mono
1 x 1000W MAX @ 2-Ohm Mono
RMS power:
SKU: TXA-750D
Originally Posted by KEE AUDIO
This is true but both amps I listed are way more powerful than the Cadence. This is something you will need to push 2 12" Type R's to there potential.
I use to love the old school hifonics amps. Now they are mass market amps. Just my opinion.
I'm going with a Cadence to run one 10 also. I'm going slightly bigger tho.... the TXA1000. I figured if i wanted to expand later I could just adjust the gain. heh. 50 bucks for another ~400rms
What sub are you going to run?
Originally Posted by wickedwarlock
I wouldn't go that far. Candence use to be owned by mcintosh, it was there sub-division. Those amps are rated rms.
The Fosgate's rating was rms as well.
